I removed and replaced my distributor to repair the O ring. I marked the distributor location on the adjusting slot, but I did not mark the rotor location. Now the oil leak is fixed but the Sami won't start. How can I set my timing again?
distributor timing
Blksami...take #1 spark plug out get piston up to top dead center....take the distributor cap off and see where the rotary button is pointing...if not at #1 plug wire on the distributor cap pull the distributor out enough to rotate the button to #1 plug wire put distributor back in and it should start...
Help in the nick of time!
Worked like a charm! Thanks!!
