Hey All,
Working on my 04 verona and the story is that ecm fuse ( fuse 15) in the underhood fusebox blows when the engine is cranked. There is a short to ground somewhere in this circuit. Fuel pump relay and fuel pump have been replaced with no change.
Any thoughts at all at what could be causing the issue? Any help would be appreciated, thanks!!!
M
I had that problem a few years ago and I put the fuse in kind of crooked, like one of the prongs on the fuse went into the fuse holder and the other one not in the hole but beside it. It's kind of hard to explain but I did that and I haven't had that problem since! I think it was burning out and causing the fuse to have a small wobble and when the engine is cranked it would blow, putting it in crooked kept it from wobbling and has worked for 3+ years.
