So I have the 05 forenza. I've had a lot of problems as far as this car goes, but today was a nightmare. I'm fairly good with wiring and adding mods to the car. Today I really screwed up though. I noticed my under glows weren't lit on one side. Found the wire completely burnt out. So I undid all the wiring for them. Also noticed that it blew the 10 amp Radio/Clock fuse I had it connected to. So I put my spare in. Put a whole new set of wires in. Reconnected everything. Turned the key. Then I noticed the odometer was blank and no cel/oil light was on. I assumed the ECM fuse blew too. Nope both fuses are fine. So I pull all my custom wiring out, because I've terribly messed up somewhere along the line. I really think I blew a relay but I have no idea where its at in this car. Hopefully I did blow one and not fry my ECM.
Another completely unrelated when the car worked. Basically the p0300 has been a nightmare for me. The things ive repaired are.
1. Coil pack
2. Spark plugs
3. Spark plug wires
4. Valve cover gasket (Had bad oil leak)
Idk what else to do for this damn code. The mechanic told me it wasn't misfiring. Which is bull because I can feel when it does. Another thing to note it only happens whenever I get above 50 or have drove over 10 miles.
Any help would be great. I'm sorta in a pickle right now since the car won't work. Which means I have no way to work ;-;. Bye bye car hello feet.
1. Coil pack
2. Spark plugs
3. Spark plug wires
