i am rebuilding an 86 samurai. (my first rebuild) i purchased flat top standard pistons. when checking the ring gap it turns out the gap was .032" not what i was expecting ( .008 - .013).
does this mean the block was bored over at one time and i need over sized pistons? or just over sized rings or both.
i'm at a loss here. this is not a daily driver just a toy to drive occasionally.
the compression was extremely low across all of the pistons. thats what prompted the rebuild.
any way, am i good with standard pistons here ( which i already have on the rods now) or do i need to rebuy oversized pistons and rings.
thanks for any help here.
You need to first determine the bore size. It may have been bored oversize already OR is simply worn beyond what your current pistons / rings will accommodate.
If found THAT significantly worn, then a re-bore and the appropriate oversize pistons / rings will be required, if not already at the maximum bore from previous machine work.
Rule #1 on ANY rebuild is to MEASURE before purchasing - this is how you know if you can "re-ring" or you need to bore, and how much oversize you need to bore, the same goes for main & rod bearings - can you just replace with standard bearings, or do you need to grind & go undersize.
From what you're saying, you're seeing a ring gap, at least 0.024" greater than you expect, that would correspond with a bore size approximately 0.008" greater that expected, and that would suggest a worn standard bore (first oversize is 0.5mm or approx. 0.020").
Have the block measured by a competent machinist and either have him supply pistons & rings and bore the block to suit, or, order pistons based on his recommendations and after you receive the pistons, have the block bored to suit.
Thanks for the replies, lesson learned. i'll have a machinist check out the block and go from there.
thanks again for the help and advise.
