I have a 2004 Suzuki Vitara and i dont know what to do. the steering has a good 5 to 6 inches of play, yet is stiff ( meaning it turns five or six inches past what is normal but is stiff) I took it to get an alignment and get everything looked at and they said there was nothing wrong and no need for an alignment but obviously something is. Please Help!!
  • check the U-joints on the steering column... and/or
  • Rack/pinion loose on frame..
  • Low fluid
...... Philip
For an alignment shop to NOT correct (or at least acknowledge the issue and recommend a fix) for a problem that blatant is crazy. :huh: Centering the steering wheel and a visual inspection is part of the alignment procedure, AND this is an unsafe vehicle to operate.
Discussion Starter · #5 ·
My thoughts exactly. any ideas on what I should do?
