Hi to all i have the following problem with my engine ,in neutral i an able to accelerate until 5500 rpm but when is engage in any speed after 2 gear it won be able to go over 3000 rpm,so the problem is when the engine have a load
any idea
thanks
What year, country, engine, transmission? Have you done a compression or leakdown test? If you have a ECM, do you have any codes stored?
I am in Australia its a 96 manual transmission 4 cylinder 1.3lt jx :)
Again, have you done a compression or leakdown test? If you have a ECM, do you have any codes stored?
Hi I An In Miami Fl And Is A 1987 Carburetor G13 1.3l ,this Is A Not Smoking Engine So I Believe That The Compression Is Ok , The Carburetor Is The Hitachi ,
Will You Consider That The Ignition Coil Culd Cause This Problem ?
