when i start my kizashi,
it turn off suddenly
all power gone
no light
nothing
after a while, door lamp on centre light on again but very very dim
later it shown " service start system"
and light on start button quit dim and flashing dimly
not functioning at all
what
is the problem ?
Battery die?
i am able to get a small car to perform jump start (battery to battery)
but not working
door lamp seem lighter a bit for awhile but couldn't help
is it the small car battery does not have adequate power ampere or what ?
pls help...
Discussion Starter #2 (Edited)
i coudn't get a new battery at this moment
thought jump start with a donor engine (small car) could solve the problem
but problem still same
light on start button is weak and dim, it flickering and shown "service start system"
and later it all turn off
nothing is functioning
and hear sound beeping for awhile then also turn
my battery is LUCAS 55D23LMF
i replace since august 2014
it is a dry type battery
is it the battery issue ?
anybody could give me advice ??
please
my kizashi start again
today i replace a yokohama 55dinL
my kizashi able to start again,
everything is normal
dash no more showing "service start system" or the triange warning symbol...
nice job.
what is the different ?
i replace yokohama 55DinL
my old battery is Lucas 55D23LMF
what is the different between D & Din ?
Size ? since the older battery is taller.
55 is stand for what ?
L, i know is mean LEFT
Glad you solved this, when you get this error its because your car isnt getting enough power normally. Means your battery isnt putting out enough to turn it over. The oddity i've found is that the Kizashi seems damn near impossible to jump start.
If your lights are dim then it's either a wiring issue or in most cases, a battery issue.
Good job on replacing the battery.
Always keep the car and remote key battery in good condition.
