If it's the same as a JT, you should be able to get to it without the need to remove any screws.
Start by carefully prising off the side panels that run full length either side of the console. I use a flat bladed screwdriver from the bottom end the slowly work my way up.
Next step is to do the same with the panel that houses your gear shift boot (or I guess selector panel if an auto). There's 4 clips, 1 just in from each corner. Again just take your time without too much force at you'll get these to pop out without marking anything else.
Cheers
Wes
