is there a relay for headlights on 2000 grand vitara high beam flicks on and off when you put on high beam but don't do on low beam
Like by themselves (not by the stalk / switch) right? :huh:
I'd look for a poor a connection and yes they have relays.
when you go from low to high they go on then they flick or black out then come on again can you tell me where relay is so I can check that first
The relay is located alongside the "underdash" fuse panel in the driver's side footwell - it is unlikely to be your problem - all that relay does is switch the headlights (both high & low beams) on or off - so if the relay were at fault, both beams would be affected.
Focus more on the combination switch itself - or the wiring.
I agree with Max, as one of the issues I found on my GV was the connectors were not coated with a corrosion proofing when they were originally assembled. They developed corrosion and made poor contact. A bit of cleaning and application of dielectric grease to keep the moisture out of the connectors solved the problem.
