1 - 9 of 9 Posts
I've got the same G413 service manual and supplements relating to my non-DLR electrics van, which unfortunately don't have a schematic of the complete vehicle like the manufacturers used to supply.
I came to a similar conclusion about no relay but wanted to ask just in case I've missed something.
I'll phone my friendly Suzuki spares counter tomorrow and see what they have to say.
Stating the obvious....you have checked the fuses and that the lamps are both ok. ?
Discussion Starter · #5 ·
Full beam works so fuses are ok.
The backward to forward motion of the hi/lo switching of the beams started getting intermittent contact on dipped beam a while ago, hence first thought about a failing relay.
If you have power at the headlight, check if the power leaves the ground side, the headlights are ground switched by the stalk...
1 - 9 of 9 Posts
