2005 Forenza had the recall repairs done on wiring behind instrument cluster. However, headlights on dim setting might work and they might not. They might initially come on but go off randomly so I'm forced to use high beams. Can anyone direct me to a fix or diagnosis?
Could be anything from bad ground to multi-function switch, when did this start?
Before dealer visit ?
It's done it since I've had the car maybe the last year. I thought about multifunction switch but don't want to spend $50+ unless I know that's the problem. Recall was done before I got car.
Then you will need a MM or 12vdc test light, and diagnose the circuit...
