I have a 08 forenza , and as of today one of the day lamps was not working so I was wondering , how in the world do u remove the low beam bulb in the first place and where can I get me a new bulb????
hi. you can gain access to the bulbs from the back of the headlight. you can follow the wires to get there. you need to unplug the light. then twist the cover, i think counter clockwise and pull the cover off. then you can remove the bulb. then you have access to the bulb. its reverse for install. when you go to replace the bulb DO NOT TOUCH THE BULB ITSELF :) the grease from your fingers will ruin the bulb. i think thats basically it. i forget the bulb size i can get that for you tomorrow. either h5 or h7. ill also double check the process for you.
