Wanted to to ask does anyone know if the head bolt torque sequence is the same for a 2006 2.0l forenza
Yep, if its the same engine, if it's a 2.0 then it should be the same pattern, values may change, usually these are noted on the head gasket packaging as different gasket construction uses slightly different values, especially if using a permatorque gasket
