2016 Suzuki Vitara SZ-T
Bare with me folks, I'm just turned 81 (but still campus mentus, just :rolleyes: )
I'm intending to hard wire my dash cam into my car but first I need to find the fuse box? I have a Nextbase 312GW with a hard-wire kit and it needs to go into a switchable fuse in the box.
Any help would be appreciated.
Tap into the cigarette lighter/accessory outlet feed at the back of the socket.
Thanks but that takes a bit of dashboard dismantling me thinks? The harness supplied has a plug on the end that (I believe) plugs straight into a fuse socket?
I'm investigating!
Take it from some one who has hard wired many an accessory - tapping into the accessory power is going to require a lot less dismantling that going to the fuse box.
For what it's worth - most Suzukis I've worked on (which does not include the newer Vitaras) have two fuse panels, the main under the hood, and the distribution panel, which is the one you want, under the dash on the driver's side.
