Hello! I have a USA 1995 Suzuki Sidekick 4 door, 4 speed automatic with a 16 valve engine with 98K miles (second engine for the car with 175K total on the car) and I have the following symptoms that I can't quite pinpoint and was hoping I could get some help.
I am also wondering if it could be timing? Could that be something that could give this crazy rev at idle? Or could there be a vacuum leak I'm missing? Not sure where to check. I retorqued everything around the engine and intake but it all seemed good. I'm pretty new to this engine so not really sure if I'm following the vacuum lines correctly.
Any other suggestions?
Much appreciated! - Joey
- Hard to start and it takes a couple tries to get it started but will turn over.
- When it turns over starts with a rough idle and then starts revving after a couple of seconds from about 800 to over 3500 rpm and doesnt stop. When I try to shift it to drive the idle would just drop and it stalls unless I keep it at about 800.
- Noticed some oil leaking from around the exhaust manifold. Cleaned it but nothing has come back after changing gasket.
- Initially smoke was coming from the exhaust manifold and I ended up removing the exhaust and replaced the gasket and retorqued everything. That stopped the smoking.
- Checked for a vacuum leak but I wasn't able to find one with starter fluid or smoke.
- I checked and cleaned the IAC and put on a fresh gasket.
- I did a quick tune up and changed some things like oil, oil filter, air filter, and swapped in new spark plugs to see if that helped but alas.
