1 - 9 of 9 Posts
anyone know how to disassemble the handbrake on a sj413 -86? the brake is on transfer case
thats called a cardon brake. Remove driveshafrpt, remove retaining screws holding drum on and its the same as any other cable operated shoe and drum brake internally
Ok thanks! I can not loosen the center bolt by hand! must probably have a machine
the main one on the yoke? Yep, that will be very tight and needs a breaker bar and the correct socket.
Pictures wont load for me. I have a tool to hold the yoke when undoing the centre nut. Big impact gun will work
you will need a 450 lbft air driven one, or similar. Not cheap
1 - 9 of 9 Posts
