i recently had to drive thru some very high flood water with my company's Carry. shortly afterwards i started to get a very loud and ominous grating noise if i have the A/C on and i try to drive forward.
i can change the gears as usual but when i start moving forward it's like something is broken.. and this only happens when the A/C is on.
any suggestions?
yup, it's possible. try also checking other belts which could have come in contact with it.
ok figured it out... was hard to do by myself.... apparently the cross beam under the vehicle got bent into the compressor and the blade were hitting the beam when i engaged the gears. lol
not a particularly helpful thread i know but at least my problem was sorted out.
now al i hafta do is change the clutch plate. and the AC fan. which were also damaged in the flood.
thanks for the advice guys.
what? There are no blades on the ac compressor. When you put it in gear? huh
