Swapping what?
Still deciding on 3 options.Swapping what?
Sure it is, it still needs more love on the inside of the car, but what a difference it is to go outside the car and turn around to look at it.That's awesome, mate.Great job, I bet it is a blast to drive around in such a clean car now.
You will need to be careful of what you swap in, the ecm, abs, bcm, tcm, hvac and 4wd controller modules all interact. These aren't quite as simple as others to do engine swaps on.Still deciding on 3 options.
1. 1.8t 20v (VW/AUDI) by moddifying the Acme Adapter.
2. Swapping a J20a and boosting it. (I will have a spare J20a laying around in a few months)
3. Boosting the actual M16a.
My next purchase will be the Fueltech that will control any of the above options.
Thanks for the advice, I will try to make my homework on this Modules. The one that I dont have to bother is with 4wd since mine is AWD no module there, also no traction control here and mine is 5 Speed Manual.You will need to be careful of what you swap in, the ecm, abs, bcm, tcm, hvac and 4wd controller modules all interact. These aren't quite as simple as others to do engine swaps on.
Bcm controls engine, abs and transmission in some cases, and even more so in an automatic
If your one is AWD with no low range, then you will have an AWD control module in place of a 4wd controllerThanks for the advice, I will try to make my homework on this Modules. The one that I dont have to bother is with 4wd since mine is AWD no module there, also no traction control here and mine is 5 Speed Manual.
2007 Model pre ESP hahahahAhh, you have that version, ok, no awd controller then.
Your one should have traction control and esp tho I believe unless its pre 2008
