1 - 9 of 9 Posts
Hey guys just purchased a 2008 grand vitara and am having problems with 4wd
When it is on N, all of the 4wd lights blink!!!!
When it's on 4H it's fine :/
What can I do to rectify this problem please?!
Sounds completely normal. "N" is only for towing the vehicle and you wouldn't normally need the ignition "on." Do you not have an owner's manual?
The manual says if lights continue to blink there is a problem in the transfer system.
You aren't meant to drive in 4H normally aren't you???
If the car is put in N all indicators blink every 5 seconds or so.... Not normal
4H is the normal driving mode. It's full-time four wheel drive!
"N" is only for towing the vehicle on all fours with another vehicle over a long distance, engine "off."
If you are trying to put the knob in N at a stop and have not put the auto gearstick in N and stepped on the brake it will not shift and the lights will continue to blink.
*Kiwi explained it. Jayde, your new vehicle ALWAYS operates in full-time 4 wheel drive which is why many of us own one.
Your transfer case switch should be in 4H for daily routine driving.
You can choose 4H-Locked in snow or mud conditions to lock the differentials and transfer case to avoid wheel spin and distribute power evenly.
There is really no reason to ever select the N-neutral position unless you are towing the vehicle. It completely disengages the drive-line. It could even roll away from you without warning.
Discussion Starter · #7 ·
Thanks guys hahaha I'm a bit blonde. Got it in for a service an look over anyway so they will let me know. 4H Works fine lol :)
Both partial and full-blondes are welcome here, I think.
I'm sorta new too after 2 years.
Search the forum to ensure your topic hasn't been covered already perhaps.
Cheers. Hope you got it worked out.
1 - 9 of 9 Posts
