1 - 18 of 18 Posts
Ok 02 tracker with 2.5 v6. I am going to get a timing set and replace my worn out one. So my questions are what all gaskets will I need to get? I know I need to replace the intake gaskets and valve cover gaskets but what all gaskets and seals are there in the front. I look on rock auto and they show a timing cover seal and a crankshaft seal both are different part numbers. Just want to make sure I have everything I need before I tear it down. thanks
Read the sticky thread on the subject and note the comments on sealant. ;)
You have the Service Manual, yes?
ok will do and yes i downloaded them
Discussion Starter · #5 ·
ok thanks also I never found a torque sequence for the intake is there one or just go from the center out?
If there is one, it's in that Service Manual. ;)
If not, yeah center out in several increasing to spec increments, would be a safe bet.
any chance I can get this another way? I cant print it out or download it with out paying. thanks
What do you use to read the forum? If you can pick it up and take it to a library, they usually have free wi-fi. BTW, What's a genuine manual worth?
Discussion Starter · #9 ·
im using my desktop at home but when I try to print it is messed up from the web page.
Ask a friend if they can download those two PDF files and print them for you.
The mentioned Library is a good idea too.
I had some trouble with the original manual but once I figured out the proper clicks is was easy. I'm also on a limited download allowance or I'd try it and give you step by step.
I suggest you try it again and pay close attention to what commands you are giving. Good luck!
If you can print at home, then you should be able to at least "cut and paste" the PDF narrative into the body of an e-mail composition, save and print THAT out, minus diagrams at least. :)
Or hit "ALT / Print screen" (developing a screen shot) and paste (right button click) that in an e-mail composition for printing.
Discussion Starter · #13 ·
I figured out a way to get it printed. I used my phone and went to the site and it would let me save it as pictures then I uploaded it to my facebook then saved it from there as a picture. I tried to just pull it off my phone but it showed up as a disc image on my phone. anyways I got it all printed out and waiting for all the parts to get here.
Discussion Starter · #15 ·
Well I have all the parts to do change the timing chains and parts. Going to start on it when I get home friday from work. Hope to have it done by saturday night but have sunday if not. Hope it all goes well for sure.
Discussion Starter · #16 ·
well i got it apart and the new chains and other parts on and rotated the crank twice. everything lines up. now to finish putting it back together. i will be posting some pictures of my spark plugs they look really bad and want to get opinions on what you think is the issue.
Discussion Starter · #17 ·
all back together and runs great. No noise from the chains anymore and no blue smoke. I cleaned the valve cover out the best I could with brake clean and drilled a few more holes. Have to drive it for awhile and see if it starts burning oil again. Thanks for all the info.
Well done! :)
1 - 18 of 18 Posts
