Hi I have a susuki alto 2014 z3 with 64.000 miles on the clock .petrol in low gears I can hear a scraping noise coming from the front right hand wheel .had the bearing changed the clutch is very high but not slipping. is it the gearbox clutch or something else thanks
Diagnosing noises from a distance is challenging at the best of times - if you're going to ask for help with a noise, at least include a video with the noise.
Post the video to youtube, make it publicly viewable and then post a link here.
Seems you may be talking 2 different things here, scraping noise & high pedal. You may need to adjust in some freeplay to the clutch to eliminate any possible contact between fingers & bearing. You say the noise is at right front (clutch is more to the left side of the vehicle). Scraping could be from anything stationary contacting any rotating part of your suspension/wheel/tire combo. Could be some debris or could be some worn or bent part such as the dust shield or a rock thrown up between the dust shield & rotor. You will have to inspect to see where the actual noise is from and which parts are involved.
Fred
Related Threads
Suzuki Forums
604.8K posts
125.9K members
Since 2004
A forum community dedicated to Suzuki owners and enthusiasts. Come join the discussion about performance, modifications, troubleshooting, reviews, maintenance, and more!
