So water was ingressing into the passenger foot well. Found this gap taped up but obviously not doing a good job. Any idea what it is for and how it should be sealed?
94735
94736
You are missing a rubber plug, Cut a piece of sheet metal or plastic and glue it in...
Assuming it's on the passenger side of the firewall, it was for either the heater core or a/c evaporator connections.
Ah I see. My van doesn't have a/c so makes sense it was once plugged up.
Any idea where I could get a cover from?
There has to be a sheet metal shop of some sort in your neck of the woods - someone doing bodywork, radiators, exhausts - that sort of stuff. Have some one hold a piece of card stock against the opening and mark the outline with a pencil, make a template 3/8 inch larger than the opening and then get a piece of sheet metal cut to fit.
