Just like the title. Turned and wouldn’t start. Squirt fuel in Carb at it ran but only with squirts. Took line off to carb and no fuel pumped. Went to filter and changed because it was blocked. Turned over and fuel pissing out line before carb. Did line up to carb and turned over. Wouldn’t start. Squirted fuel and started and would run as long as I was squirting fuel. Don’t know how the electrical works if there is no power opening up the fuel to carb. If you know please explain what may be wrong. Thanks in advance!! Joe
ok, was just confirming it was actually carbed.
It sounds like the float needle is stuck closed in the carb not allowing fuel into the float bowl, hence the no start and only running when you squirt fuel down the carb manually.
I’ll snap a pic for you. Maybe that is why it’s hassling me when trying to fix it. It isn’t starting at all by itself so I don’t think that’s the problem. Thanks for reading and all your thoughts.
Fuel to line not attached in last picture. And with line on it won’t start. I have been busy with Auctions the last month so didn’t have time to send pictures. Thanks in advance for the help to get my Zuki running ?
Darrell, my thoughts would be be looking at he fuel shut off solenoid for operation, or dirt under its needle.
That should get power at key on in ign position? I don't have a diagram handy but that would certainly account for the original posters issues, no fuel getting into float bowl.
This of course assumes fuel actually comes out of the fuel supply line when its cranked.......does it?
On my SJ413 with ignition on the B/W wire had 12v/battery voltage and the solenoid valve was earthed, this carb is somewhat more complicated and the ground supplied by the ECM.
The wiring diagram is just great thanks. As you can see from the pictures the colours are going in one end and coming out different colours the other. I trace them through to the other side with continuity. So there is a connection. There is power going in on the hot (b/w) wire but there’s no power going to the solenoids valves. So I’m confused how these should be working. Thanks again for all the responses. ?
Maybe the wiring on the carb is from a newer or older carb as opposed to the 1988 1/2 year on the Zuk’s. so the wiring colours are different. I have had it running since this engine was put in. Thought I would let you all know.
Just to hear it again, I had a pop bottle with a pin hole in it full of fuel. Put some in went in Zuke and turned it over. It Ran. So I ran and put more in the carb hoping it would clean up and start working. Ran it for about 30-45 seconds. Stopped feeding fuel and the Zukie stopped too. That is where we are at. ?
I took apart the old carb that was on the previous engine. It has the y on the intake for fuel. I imagine the rest is very similar. Blew in the holes and no air went through. Too the y off and seen dried fuel blocking. Cleaned it out and blew in the hole where that y went. It was blocked too. Seems to be the normal. So I cleaned that out too. Now the float on that old one is working. I will do the real operation in the newer carb and hopefully the problem is similar to the older one ?
Ok so this is the latest. I took the top of the carb off. Float would not move. Cleaned it up and air is getting through now. That’s good. Bad part is the high idol springs are sitting on side closest to firewall are not sitting right and I can’t find a picture online. Could someone send me one the way it should look. Once it is sitting right it is just a mater of putting everything else on and it should be a runner. ?. Thanks.
Top is where I goes on carb closest to firewall. Second pic is the idle. I just need some pictures with the carb together to get idea how it should look together.
step 221 gives a good picture. It still doesn’t show exactly where the spring goes. It never is taken apart like I did with the screw holding the spring in place. I think I’ll figure it out. Thanks for the pics!!
Ok back together running. Have to fix the idol but it is getting fuel and running. Thanks to everyone for all their thoughts and pictures. I was going to send you all a video to hear it running but apparently I can’t. But it is running. ??????
I just wanted to make sure before I took the carb apart. I had to check all the possibilities! But yes the needle was stuck and the line blocked going to the needle and float. ?
amazing how simple blowing a bit of air into a line will prove a fault exists...34 posts later and I gave you the solution in post #4. Glad you have got it running, now you know how scary carbs look, but how a small blockage stops things cold. And you fixed it yourself and learned things along the way. Well done.
Related Threads
Suzuki Forums
604.8K posts
126K members
Since 2004
A forum community dedicated to Suzuki owners and enthusiasts. Come join the discussion about performance, modifications, troubleshooting, reviews, maintenance, and more!
