I have a 1990 Geo Tracker it starts and then when it warms to kick down throtle it dies. I have put three fuel pumps in. Three computors, three regulators, a new distributor complete, a coil. and it still does the same thing. Does anyone have any idea what is causing this? I have found no mechanic that can help.
Check for vacuum leak in the intake manifold. Start the engine and spray some startgas on the vacuum hoses, if idle increases you have a vacuum leak.
Check for loose or damaged connections at distributor, coil or alternator.
