..isn't working.. as the name states. cluelesss with samurai's.
so pretty much the fuel pump is working, fuel filter isn't clogged, all lines are clean, just not coming out the injector. we poured a little bit of gas in 3 times started up till the gas burned out. anyone ever cleaned one?
any help would be great.
Well i hope for your sake that its just a clogged injector or something because i know that if the ECM goes it usually shuts off the fuel delivery system.
don't know what help i can be but i have the exact same problem on my 1990 8v tracker i was trying to see if the samurai and tracker/sidekick had the same throttle body setup fuel pump and filter are new but injector doesn't work all the time i can't find a new or rebult one for under 220$!!!! i am stealing one off a buddy's to see if it works
Years ago, my son had a LTD that did the same thing. It would fire off when I poured fuel down the intake. I ended up replacing the computer and it ran great.
I would say ECM also! You may want to pull the injector out and make sure that the needle on the end moves. I have had a couple that have sat for awhile and the needle sticks. It only moves in and out a small amount so don't get crazy with it. Just put the needle up against a hard surface and push in on it, you will here a small click sound as it moves. But again ECMs are know for going out on these.
as soon as you turn the key on you should hear the fuel pump relay under dash passenger side beside horn relay- honk horn a few times to locate it.
Check the wiring - this also sends sig. to ecm for injector push.
