2002 Chevy Tracker ZR2 4x4 4DR 2.5L
I'm in the middle of swapping out my Suzuki H25a (2.5) for a Suzuki H27a (2.7) as described in a separate post, and I'm not sure which fuel injectors to install.
The 02 Chevy 2.5L uses the same H25a engine found in the Suzuki Grand Vitara.
Suzuki offers the following part numbers:
For the 2.5L injectors: 15710-67D00.
For the 2.7L injectors: 15710-52D00
I've been unable to find out the differences between these two. I did learn (according to Amazon at least) that they do not interchange, and neither do the seal kits.
Per some advice I received elsewhere, I'm trying to use as many parts from the 2.5 when reassembling the fuel delivery system for the 2.7 - intake, fuel rail, sensors, injectors and so forth. I'm stumped whether to try to fit the 2.7 injectors onto the 2.5 intake and fuel rail, or if that's even possible.
Am I at risk of running lean with the 2.5 injectors? Or somehow starving the engine of fuel?
Can anyone point me in the right direction for making this decision? Should I be looking at fuel pressure? Flow rate of the injectors? Both? Anything else?
There are also some differences between intake manifolds and TBs for the 2 engines so they also don't appear to be interchangeable. At least not without some difficulty.
I posted a similar question on the XL-7 1G community, and so far no response.
Any advice appreciated.
