guage reads empty when full of gas then drops as I run it .can anyone help with a fix? 1992 samurai jl
Take your pick ...
a - there's a bad connection in the gauge/sender wiring (this includes the ground at the tank)
b - the gauge or sender is defective.
c - someone has replaced the gauge sender with a non standard one.
d - someone has tampered with the gauge.
Fuel gauge not reading correctly
The fuel gauge on my 1996 tracker 4 door reads 3/4 when full, reads 1/4 when it is half full.Behind the left tail light are wires coming from the tank. My wheel well rusted out so mud, water and snow with salt got inside the top of the well area . My fuel gauge was not working at all. There was a small flat plastic piece with metal above the well that was all corroded. I removed it and connected the two wires together.That is why it works now as it does. One wire was black with red stripe and the other is black with blue stripe. I need to find that little flat plastic piece. Can anyone help me find one?
