Hello!
My front windshield sprayer has stopped working and I cannot figure out which fuse to check. My owners manual doesn't have it listed. Is the back window washer pump the same as the front or are they different? The back one works just fine but the front stopped working sometime in March. Any help would be greatly appreciated!
The pumps will usually be identical, and will be fed from the same fuse, so if one works, the fuse is probably just fine - if the cable length permits, swap the electrical connectors and "re-test" - which one works now?
Looking at the workshop manual the front wipers and washer use the same fuse so if the wipers are fine, so is the fuse.
The rear has a separate fuse in this case.
Dam pumps are hidden behind the bumper though :(.
