What replaceable parts are there in the front of a 1987 sammy? I replaced the tierod and the shocks and the steering stabilizer but front end still alittle loose?
Joints in the steering shaft maybe, but more probably steering gearbox. You should be able to grab the steering shaft from under the hood and twist it back and forth to see how far it goes before it budges the pitman arm. If you find that this is it there is a lot of information on adjusting it if its not to badly worn.
Upper and lower kingpins on each side. With the tires on the ground, grab the top of the tire and shake... If it moves in and out you need to replace them.
X2
