Hi to all, my samurais leaking oil from the differential on the right front axel, have any of you had this problem before? :confused:
Yep, I just bought mine a month and a half ago and both sides were leaking. You have to replace the axle seals. Best to completely dismantle both knuckle assemblies and replace seals as required. Not too big a job if you have a manual.
Hi thanks for the replay ,I do have the manual,can you tell me where i can buy this seal ,
thanks
virgopelo
From a Suzuki dealer or if you disassemble the front diff you can get a dimension off the old one and get one close enough from a bearing supplier. They are cheap.
