Hello. So I currently have a 2006 reno, 5 speed manual. My transmission went out yesterday. So when looking up new Transmissions it kept popping up with forenza trans. Can these two be swapped out? Or are the different builds?
there could be many reasons
1) worn out... happens ALOT
2)moisture/dirt RARELY a plug will not seal properly and cause connections to corrode(rust) and will cause a circuit failure (loss of power to the sensor,etc) causing a code
3) my all time favorite .... electrical, ive seen rare cases where a voltage is not what its supposed to be and caused the initial failure AND damaged the replacement parts
