I am selling my 97 tracker with sas on 35s and geared...
16v with header
auto trans/4.24 to1 tcase gears
-5.13 diffs with spools in both
-alter ego rear upper third link
-full high steer setup
-sami front axle sas with cj leafs and chromoly shafts,trussed and diff guard
-brand new gas tank
-rear lift with +4 tj front coils
-bilstein front shocks
-rear disc conversion
-brand new bfg km2 35s
-full exo cage
---rig needs exo cage re installed due to removing body lift.also needs body bolts re tightened and brakes bled.maybe a once around on the other bolts too.this is a unfinished but almost finished project so the chromoly shafts and tires and whole project has ZERO miles....i plan to finish it soon and maybe do some work on it this weekend.once its a turn key wheeler then price will go up accordingly..i will take no less than $4000 for it as is..i can text pictures and prefer to use text or calling since i dont get online much.located in flushing/mt morris michigan..call or text 8109556825...thanks
I was thinking of putting rock crawler gears in my' 97tracker I wondering what improvement it made on low end torque and did the motor have enough power you said you run 35's I am running 33's so that would make a little difference.
Regards' 97 tracker
