Location is Perth, Scotland, UK. You will need to tow or trailer it as MOT expired. Drives fine.
Selling, for spares or repair, a 2006 Grand Vitara DDIS, 1.9 4x4. It has failed it's MOT and unfortunately I'm not able to weld or fund the repairs at this time.
Engine has genuine 83000 miles.
New stuff: (have receipts and service history)
New front wheel hub bearing units x2 fitted 2018.
New hanes auxiliary/fan/serpentine belt fitted Autumn 2017
New Yokohama Geolander A/T fitted 2017, like new.
New disks and near side calliper ~ 2017
Had some welding last year for MOT 2017
New Front Strut bearings x 2 ~Feb 2016
New BF Goodrich T/A x 2 fitted 2016 like new.
New battery ~2016
MOT failure list below. Welding and brake pipes are the problems for me, the rest is new parts.
Unfortunately, the Exhaust eroded at down pipe below dpf and I lost the 2nd pipe and back box when i went over a speed bump...at slow speed! Needs 2nd pipe and back box...priced these on eBay for £40 & £80 and you would need a flexible joint to connect. Suspension arms are around £45 on eBay.
I've never done welding or replaced brake pipes so it's beyond my skill level.
This is a great forum with loads of helpful people, so hopefully someone here can fix it, use it for parts or as a farm vehicle...or my preferred option; go to town on it, roll cage it up and enter the Dakar!
Starts first time every time in coldest weather and 4x4 system works 100% and unstoppable in the snow.
Registration SV06DVZ
MOT failures:
Exhaust system not adequately supported (7.1.1)
Exhaust has a major leak of exhaust gases part of exhaust system missing (7.1.2)
Emissions not tested (7.3.A.1)
Nearside Rear Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings inner sill (6.1.B.2)
Offside Rear Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
Offside Rear Vehicle structure excessively corroded within 30cm of towbar mounting (6.6.6)
Nearside Rear Brake pipe excessively corroded (3.6.B.2c)
Offside Rear Brake pipe excessively corroded (3.6.B.2c)
Nearside Front Brake pipe excessively corroded (3.6.B.2c)
Offside Front Brake pipe excessively corroded (3.6.B.2c)
Offside Front Brake pipe excessively corroded to rear at rear (3.6.B.2c)
Nearside Front Brake pipe excessively corroded to rear at rear (3.6.B.2c)
Nearside Front Suspension arm has excessive play in a ball joint (2.4.G.2)
Offside Front Suspension arm has excessive play in a ball joint (2.4.G.2)
Please beep me if interested
Update: I have added some pics and correction to miles below:
Update: I cannot seem to upload pics or documents even after trying google which sends me off to internet la la land, so please beep me if interested and I can email docs and pics.
Correct Engine Mileage is 81,793 miles
Engine number is F9Q017972
Chassis #: JSAJTD44V00111304
ABS 260556 Stabilizer Link fitted 2016 (UK Passenger Side Front)
2 New Yokohama Geolander fitted, not one.
