Hi all, I've recently brought a 2011 suzuki swift. It's the 1.3L automatic cvt gearbox.
It shows the automatic gearbox light after a long drive which then after a day or so switches back off.
I've taken the car to my local mechanic and put it through a scanner. And its showing the fault code 00,00,08,41 and the description is "please research before proceeding".
Does anybody know what that fault code is? I've tried to research and had no luck. Thanks all in advance. :)
Also forgot to add, between 3000rpm and 4000rpm the cars revs judder causing the car to judder aswell.
"fault code 00,00,08,41 and the description is "please research before proceeding". "
This is not a valid code, have the ECU scanned again and post the result..
or the mechanic using a reader that only provides raw hex code and doesn't translate it to the OBD2 codes. Find a mechanic with a decent scanner
why do they still make CVT transmissions? horrible things.....
