my internal fan heater thing has stopped working on the first 3 settings but works on full whack, any ideas?
Defective switch, wiring or resistor - to get the lower speeds a "multi section" resistor is wired in series with the motor, and as you select a higher speed you bypass one or more sections of the resistor until the entire resistor has been bypassed applying full voltage to the fan motor.
