i HAVE A WEIRD NOISE COMING FROM THE FRONT OF THE MOTOR THE ONLY THING i NOTICED IS THAT i COULD MOVE THE FAN BLADES WITHOUT MOVING THE PULLEY THAT IT IS ATTACHED TO. A.K.A. THE PULLEY IS THE WATER PUMP PULLEY, SO IS IT A BAD BEARING OR SOMETHING ELSE THE CAR RUNS PERFECT 1987 SAMMY.
Posting in all caps is considered shouting - I'm sure you didn't mean to shout. It also makes your post quite difficult to read.
Some vehicles are fitted with a "viscous coupled" clutch fan, which allows the fan to freewheel when it's not required, thuse reducing noise & fuel consumption - depending on which market it was built for, your Samurai may or may not have a clutch type fan - so being able to rotate the fan without the pulley turning MAY be normal.
