My 88 Samurai is all stock and runs well, but needs all exhaust componets repalced (the manifold is still good). Can anyone tell me if the Calmini system is worth the $600? I would like to get a bit more power as well, but have heard the 2" pipe is too large for the little 1.3L and may even rob me of power. Plans are to upgrade the carb at a later date.
I got my new pipes from Roadless Gear for $325. It is 2" comes ready to bolt in from the manifold back, including a free flow cat. It sounds great, and passed smog no problem here in California. It is a easy install no clamps or welding, just bolts together. If you get the header to go with it they say even more horses. Make sure if you buy the exhaust and plan to get a header to do it all at once cause the custom header will of course be different. Glad I did the upgrade. Good luck!
Thanks Zami! I suppose it runs better then. I will look into their website, thanks for the reply!
