UK-spec 1997-98 Vitara (Santana), 4 cylinder, 8 valve with single point fuel injection. 3 inch lift.
Hi folks,
I'm new here, but having enjoyed the benefits of lots of useful info from others, I thought I'd share some learning (which I couldn't find on the forum) in case it is useful for anyone else. Being new, this may just be a load of school-boy errors, in which case please feel free to put me right / disregard!
I bought my: UK-spec 1997-98 Vitara (Santana), 4 cylinder, 8 valve with single point fuel injection (SE416) online. It was sold-as-seen with:
- with a blow on the exhaust - surely a simple fix?
- loss of brakes on tight cornering, presumably due to a 3inch lift kit stretching the old near-perished brake hoses (should find out tomorrow whether new extended hoses fix the issue)
- rev counter working intermittently - I gather from reading around that this is likely the Cam Position Sensor dying
First on the list, I thought it would be a simple job to fix the exhaust... it wasn't....
Issue 0 - there are so many variants and I haven't found an easy way to work out the spec of my vehicle - I think have pieced most of it together, but it has taken ages - have I missed a simple way of looking it up? I have the vehicle registration (V428 EUJ) and VIN (VSEETV01VNA209743) and I have used PartSouq but even then there are multiple options - endless squinting and cross-referencing - surely in this digital age there is a better way - is there somewhere a register of Forum members with photos of their vehicles and the corresponding spec to help newcomers?
Issue 1 - using the vehicle registration number on parts sites did not give the right model (e.g. Europarts, AutoDoc). Sometimes you can trust the images but not the text, sometimes vice versa. So frustrating and time-consuming!
Issue 2 - when I eventually found someone who could sell me what I think are the right parts (Car Parts Online | Replacement Car Parts | Discounted Car Parts - by ringing them and sending them photos of the old parts and links to what I think is the right page on PartSouq), they were not like-for-like and the compatibility of the various bolts, springs, gaskets was terrible
So here is the outcome:
What came off:
What PartSouq suggest (which looks right):
Exhaust Pipe 1 (downpipe from the manifold) - OnlineAutomotive - part number EFSZ8007 - looks wrong in the image, and what has arrived has a simpler curve, but seems to have worked - Search results for 'EFSZ8007'
Exhaust Pipe 2 (Catalytic Convertor) - OnlineAutomotive - part number ECSZ5002 - looks wrong in the image, and what arrived has a much smaller CAT section, but seems to have worked - Search results for 'ECSZ5002'
Muffler/Backbox - I didn't change
Exhaust Springs - OnlineAutomotive EMB012 were specified with the above Exhaust Pipes, but were too short (didn't fill the gap between the bolt head and the locating shoulder)
Instead I used the ones from https://www.onlinecarparts.co.uk/ (who are actually the big German firm AutoDoc) Article №: SZM-105 Manufacturer: VEGAZ and I think I picked up some identical ones from EuroCarParts too.
Exhaust Bolts - OnlineAutomotive EMB011 are almost identical to others I ordered, but have thread right to the end and so were much easier / possible to fit
The ones from AutoDoc (Article №: 765-903 Manufacturer: FA1) had the last few threads cutaway (to enable easier locating), which makes the threaded section too short to reach (probably due to the poor fit of the Ring Seal)...
Exhaust Ring Seal (big fat "gasket") between the manifold and the downpipe, and also between the downpipe and the catalytic convertor - marked as being the same part number in both locations everywhere I looked, but I ended up with 2 different versions and had to use one of each to make it work
Exhaust Ring Seal (big fat "gasket") between the manifold and the downpipe - used the smaller version OnlineAutomotive EMG068 which doesn't seem to fit very well, but I got it in and the exhaust is not (yet) blowing.
Exhaust Ring Seal (big fat "gasket") between the downpipe and the catalytic convertor - used the larger version from https://www.onlinecarparts.co.uk/ (who are actually the big German firm AutoDoc). Article №: 80547 Manufacturer: WALKER. Not a great fit, but the one which came with the 2 new pipes didn't fit at all.
Gasket between the catalytic convertor and the back box - I used both the thick ring one from OnlineAutomotive EMG013 and flat triangular one with the "corners" cut off to provide sufficient thickness (perhaps necessary since I didn't change the back box). I think the flat gasket came from EuroCarParts.
When installing, I had to first mate the downpipe and the catalytic convertor very carefully to get the Ring Seal to sit centred (I hope), since it doesn't locate very nicely, and then mount them both together in to the vehicle. This makes fitting the rubber hangers more difficult.
The parallel hole (figure of 8) rubber hangers are similar enough from all of the different sources. But I got the 90 degree off-set hangers from Onlinecarparts / Autodoc Article №: 763-902 Manufacturer: FA1. I forgot/didn't get with the rubber hangers the sleeves which go in the hangers so had to reuse the old rusty ones.
What a faff. Has taken weeks. Should have taken it to a garage, but I thought if I did it myself I could justify buying this monster DEWALT DCF899N-XJ 18V LI-ION XR BRUSHLESS CORDLESS IMPACT WRENCH (to undo the seized bolts between the downpipe and the exhaust manifold) and I have to say, it probably is worth it - 950Nm of torque! - no more jumping up an down on wheel nut wrenches ;-)
The other part of the tips for releasing exhaust bolts on this forum (which worked a treat - thanks) - 2 weeks of daily soaking in Penetrating Oil, then heating to glowing with a MapGas blow torch (smoke wrench) and then using an impact wrench - Hi! Exhaust bolts and exhaust questions
Apologies for the long ramble! Has been cathartic - ready for the next challenge...
Ben
What came off:
Ben
