Suzuki
Name: F5B DOHC Turbo
Type: 547cc EFI DOHC 12-valve 3-cyl turbo
Power: 47kW @ 7500
Torque: 76Nm @ 4000
Sources: 88-89 Suzuki Alto Works RS/R
Type: 657cc EFI OHC 6-valve 3-cyl turbo
Power: 43kW @ 5500 (90-91), 45.5kW (92), 47kW (95-on)
Torque: 86Nm @ 3500 (90-91), 87Nm (92), 98Nm (95-on)
Sources: Every EX660 90-91, every PS 1992-on (both same as Suzuki carry van), 92-93 Autozam Carot
Name: F6A DOHC Turbo
Type: 657cc EFI DOHC 12-valve 3-cyl turbo
Power: 47kW @ 6400
Torque: 85.3Nm @ 4000
Sources: 1994 Cappuccino, 91-93 Alto Works RS/R (4WD east-west), 92-93 Autozam AZ-1 (mid mounted)
Name: F6B DOHC Turbo
Type: 658cc EFI DOHC 12-valve 3-cyl turbo
Power: 47kW @ 7000
Torque: 82.3Nm @ 3500
Sources: 92-93 Cervo SR-Four
Name: K6A DOHC Turbo
Power: 47kW @ 6500
Torque: 103Nm @ 3500
Sources: 96-97 Alto RS/Z
Type: 1297cc EFI DOHC 16-valve 4-cyl
Power: 86kW @ 7500 (74.6kW in Aust version)
Torque: 110Nm @ 6500
Sources: The good old Swift Gti donk, 86-96, late model jap version had 11.5:1 CR.
please post the spec of other engine not on the list
complete details including compresion ratio.. this a three engine list f5a, 80 , 84 , f5a from 85-88,f8b 81 84... see the sorce link for details
ENGINE IDENTIFICATION*
F5A
F5A
F8B
CAPACITY (litres)
0.543
0.543
0.796
COMPRESSION RATIO :)1)
9.2
9.2
8.7
DEVELOPED KILOWATTS @ rpm
19.2 @ 6000
19.2 @ 6000
29.5 @ 6000
TORQUE (Nm) @ rpm
35 @ 4000
35 @ 4000
59 @ 3500
VALVE CLEARANCES
Cold, not running(1)
Inlet (mm)
0.13-0.18(1)
0.13-0.18(1)
0.13-0.18(1)
Exhaust (mm)
0.13-0.18(1)
0.13-0.18(1)
0.13-0.18(1)
COMP. PRESSURE (kPa)
980-1325
980-1325
980-1275
Maximum Variation (kPa)
100
100
100
IGNITION SYSTEM
SPARK PLUGS
NGK BR-5ES
ND W16EX-U
NGK BP-5ES
Gap (mm)
0.7-0.8
0.7-0.8
0.7-0.8
Torque (N m)
24-29
24-29
24-29
DISTRIBUTOR
Denso 33100-78319
Denso 33100-78319
Denso 33100-78410
Model or Service Number
029100-6750
029100-6750
029100-7270
Gap (mm)
0.4-0.5
0.4-0.5
0.45
Dwell (...°)
60±2
60±2
60±2
Spring Tension (N)
NS
NS
NS
AUTOMATIC ADVANCE
Centrifugal - Starts (rpm)
900-1300
900-1300
NS
Intermediate (...° @ rpm)
7 @ 2000
7 @ 2000
NS
Maximum (...° @ rpm)
14-18 @ 3000
14-18 @ 3000
NS
Vacuum - Starts (mm Hg)
60-150
60-150
NS
Finishes (mm Hg)
220
220
NS
Maximum (...°)
7-11
7-11
NS
Total Advance (...°)
21-29
21-29
NS
CONDENSER CAPACITY (µF)
0.25
0.25
0.25
COIL
Denso 33410-58013
Denso 33410-84010
Denso 33410-58020
029700-4960
029700-6001
029700-5560
Primary Resistance (§)
3.0(2)
3.0(2)
3.0
Ballast Resistance (§)
1.5
NA
1.5
TIMING SETTING
Degrees B.T.D.C. (@rpm)
10 ± @ below 950
10 ± @ below 950
7 ± @ below 900
FUEL SYSTEM
FUEL PUMP
Mechanical
Mechanical
Mechanical
Pressure (kPa @ rpm)
19.6-29.4 @ NS
19.6-29.4 @NS
20-30 NS
Volume (L/min @ rpm)
0.2 min. @ 2000
0.2 min. @ 2000
NS
CARBURETTOR
Mikuni
Mikuni
Mikuni
Auto. Choke Setting (notches)
NA
NA
NA
CO% - Air Fuel Ratio :)1)
NS
NS
NS
Mixture Screw
Limiter cap
Limiter cap
Limiter cap
IDLE SPEED (rpm)
950 ± 50
950 ± 50
900 ± 50N
CHARGING SYSTEM
BATTERY Polarity
Negative
Negative
Negative
SAA Assembly
12-1
12-1
12-1
Ampere Hours
24
24
40
BELT TENSION
10-15 mm(3)
10-15 mm(3)
8-10 mm(3)
ALTERNATOR / GENERATOR
Denso 31400-78010
Denso 31400-85510
Mitsubishi A1T32371
021000-8130
100211-1470
31400-78431
Output (A @ rpm @ V)
35 @4000 @ 14.0
35 @4000 @ 14.0
40 @4000 @ 14.0
Field Resistance (§)
4.0-5.0
4.0-5.0
4.0-5.0
REGULATOR
Denso 31400-78010
Denso 31400-85510
Mitsubishi A1T32371
02000-3670
100211-1470
31400-78431
Voltage Regulator (§ C)
13.8-14.8 @ N.O.T.
13.8-14.8 @ N.O.T.
14.1-14.7 @ 20
WHEEL ALIGNMENT
Caster
+3°15'
+3°15'
+3°15'
Camber
+1°20'
+1°20'
+1°20'
Toe In (mm)
2-4
2-4
3
Toe-Out on Turns
Outside Wheel
32°
32°
32°
Inside Wheel
38°
38°
38°
Steering Axis Inclination
12°50'
12°50'
12°50'
TORQUE SPECIFICATIONS
Cylinder Head (Nm)
55-60
55-60
55-60
Con-rod Bearings (Nm)
28-32
28-32
28-32
Main Bearings (Nm)
55-60
55-60
55-60
src:Mightyboy Specifications
for f6a sohc spec...
additional info
Displacement, cc: 657
Frame: GF-HN11S-DBXX-D2
Price of new car, thousands yen (Tokyo area): 1255 (~$10400)
Exterior dimensions (LxWxH), mm: 3395 x 1475 x 1595
Interior dimensions (LxWxH), mm: 1685 x 1220 x 1265
Wheel base, mm: 2360
Treads (F/R), mm: 1280 / 1280
Ground clearance, mm: 185
Curb vehicle weight, kg: 820
Seating capacity, persons: 4
Doors number: 5
Min.turning radius, m: 4.6
Fuel tank capacity, l: 30
Engine model: F6A
Max.power (Net), kw(PS)/rpm: 60 ps (44.13 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm: 8.5 kg*m (83.36 N*m) / 4000 rpm
Power density: 13.67
Engine type: Water cooling serial 3 cylinder SOHC6 valve IC turbo
Fuel system: EPI (electrically controlled gasoline injection)
Turbocharger: Turbo with intercooler
Fuel type: Unleaded regular gasoline
LEV system (Low emission vehicle): No
Compression ratio: 9.2
Bore, mm: 65
Stroke, mm: 66
Fuel consumption at 10-15 modes, l/100km: 5.6
src:1999 Suzuki Kei 5 door X type description
