1990 Suzuki Alto Works RS-R
Not sure how it's mounted in the Every, but you could probably take it out from the bottom if you remove sub frames. Otherwise, you could take it apart from above, but takes much longer.
out the bottom there are no sub frame to remove. Apart from above is not possible even with head etc removed. Car is a van
