i have an 2004 suzuki verona and i was wondering how to remove it from the transmission in order to pull?
thank you
The engine and transmission have to be removed as an assembly from the underside of the vehicle, then the two can be separated. I just found this out wanted to replace a head gasket. The timing components can't be removed in the vehicle. If you remove the air cleaner housing you can see that the engine mounts only disengage from the underside.
Sorry.
if you want to remove the engine so you have to remove engine and transmission as well because without this you cannot pull the engine as an assembly from the underside of the vehicle then you can separate it. its suggestion you just bring the vehicle to car care shop to pull the engine they will do with more efficiently.
