can anyone help with where this switch is on my 2001 1.6 jimny it started misfire and rough idling so i have filled the tank with new fuel and injector cleaner and runs ok now but the light remains on it i believe it is supposed to be by the left hand speaker i cannot find it-----help
I'll assume its a 1.3. There is no reset switch, if its Spanish built then its probably OBD2 and codes can only be reset using an OBD2 scan tool/code reader. If its Japanese then it may be OBD1 and you need to disconnect the battery for a few minutes.
Either way you need to read the fault codes and fix the fault or the light will come back on again.
