Smokey - what is the color of the smoke?
Rattley - What's rattling?
Could be time for a rebuild if you caught it before any damage has happened to the cylinders. But you will need to tear it down to assess the damage either way.
smokey and rattly
well the smoke is normall grey colour but lots of it, and the rattling occurs when its warmed up not cold,
thanks
smoke, raddle and roll
check the pcv valve. it is common for these to plug and then oil is sucked in through air intake. you will see oil in aircleaner and duct tubes
A raddle when warm might be binging. check timing otherwise a teardown is required
