DO NOT USE GASOLINE. All I can think of is BOOM !
First off is the engine ion or out on a stand?
I have cleaned many engiines that have 35 + years of crud on them using this method:
The best way to clean an engine is to protect all the electrical and intake areas, soak it down with a solvent such as Varisol, and give it a good brushing with a parts brush using more Varisol. Then immediately put the engine in a large garbage bag and let the Varisol loosen off the crud overnight. Then use your pressure washer being extra careful to not damage or soak any wiring or get any water in the engine via vents, exhaust or intake.
