My 2001 Alto Suzuki,very efficient car is acting funny since a month now,my son removes the battery terminal with the key inserted in the ignition at ACC,so thereafter the blinks the check engine light and won't start,the coil shocks so well and I check the immobilizer and ignition on the computer and it's fine but no way to check the ECM because the car wasn't designed with diagnostic connector.
So am stuck and my car is just lying at Auto shop with no solution
i need urgent help
Check the power and grounds for the ECU
I'd be quite surprised if your 2001 Alto didn't in fact have the diagnostic connector under the dash, I don't know how much of a difference it would make as it's quite likely to be an OBDI system - I'm also curious as to how you "checked the immobilizer and ignition on the computer" - which computer?
Step one is going to be to determine why the check engine light is blinking.
Check Engine Light
