i pulled the engine and trans togather..when i reinstall should i install them togather, or separate..want to do it the easy way!
Depends on your setup.
Was it easy to pull?
If you have the room to get the propper angle then together is easier.
If limited then separet is not that much more trouble.
Just need to get the right angle and it will slide right in.
Will need jacks to hold the tranny in place.
Don
