Hi all,
UK limit CO is 0.3 and at present it's 0.6
1.2 wagon r emissions using this forum so far I've changed the cat and lamba sensor so that side is passing ok
I've cleaned the throttle body the air valve,
I removed the coolant temp sensor can anyone tell me what tests I can do with it to know if it's at fault there are 3 wires with a multi meter I get readings on 2 of them so am I right in thinking 1 is for the gauge and the other is for the ecu so what are the test ranges
Is there any test I can do on the air valve to make sure it's working
Great forum
Thanks Tom
Discussion Starter #2
