Hello,
I am new on here and I don't know if anyone has asked this yet but I haven't seen anything similar in the searches.
Anyway, I have a 2005 Suzuki Swift ZC11S with the M13A engine from Japan, mated with the P30 manual gearbox having the electronic speed sensor. Lately I noticed that it has developed the infamous input shaft bearing problem. I know it's a common problem and I was told that even if I repair it the probability is it will manifest itself again. So I started thinking of replacing it with a more robust gearbox, namely the ZN2 or ZN5 from the 1.5. Some searching I did is indicating that the ZN2 has the electronic speed sensor while the ZN5 doesn't (is this correct?), so I ruled out the ZN5 gearbox.
Then I started looking into the gear ratios for the different Swifts because I read that the ratios for the 1.5 are a bit longer, and when I saw the 57KA gearbox from the Swift Sport I was surprised to see that while the 1st and 2nd are similarly geared, the ratios for the 3rd, 4th and 5th gear are geared lower than the stock gearbox (when taking the Final Gear ratio into consideration). This started getting me excited and I started looking to see what the differences between that gearbox and mine are.
Looking at the schematics, I am seeing that the only difference is the speed sensor ring (No. 21 in the schematic and No. 6 in the differential exploded diagram).
Also it seems that the differential shaft has a groove in it that seems to be able to accommodate this speed sensor ring (mine on the left, SSS gearbox on the right).
Does anyone know if this speed sensor ring would fit the 57KA and if it fits, would the gearbox then work and correctly show the speed on the standard Swift (after transferring the sensor to the other gearbox)?
Also would the stock driveshafts be compatible with the 57KA gearbox and is there anything else that I might have overlooked in order to make this gearbox work with the M13A engine on the ZC11S chassis?
Thanks a lot for your patience in reading about my crazy ideas
