I had a new EGR valve for a 1997 Geo tracker 1.6 engine, and put it on a 1987samurai 1.3 Engine. Now my engine will not run right. Is there a difference in these two valves. I know they do not have the same part number.
are you sure the rest of the egr system is hooked up correctly? (EGR modulator, egr VSV, bi-metal vacuum switch, all the hoses that go to all of those components) My modulator was bad and it made the rig run super lean. Failed my smog as a gross poluter. Replaced that one part and It's running clean as a whistle.
ok wolf.. that's like THE biggest most visable vacuum hose under the hood!
well at least you didn't do something like leave a torque wrench sitting on top of the carb when you cosed your hood. (i've NEVER done that before...:rolleyes:)
The important thing is that YOU found the problem before someone else did.
