Where is the Engine Coolant Temperature Sensor located on the 6 cylinder version?
I can't find it anywhere.
Only info I can find.
Dunno if it's correct or not :D
Hi Darrel.
I know that a lot of time has passed since you post this picture, but actually i'm a epica's owner with a IAC problem!!. when the engine starts the RPM goes up 4000 RPM!! i need to know if the IAC valve is working good or is jammed. I would like to ask you if you have a picture with the epica's throotle body showing the IAC valve location?
P.D: soryy for my bad english!!
